Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3
There is a clip on the upper left side of the upper panel. Use the plastic opening tool to pry the clip off of the phone. The upper inside panel flips up easily off of the phone case once all the clips and screws are removed. If the panel does not pull off easily, check that you have removed all of the screws. There are ribbons that need to be removed as well. Be sure to carefully pry them off of the board
  • There is a clip on the upper left side of the upper panel. Use the plastic opening tool to pry the clip off of the phone.
  • The upper inside panel flips up easily off of the phone case once all the clips and screws are removed. If the panel does not pull off easily, check that you have removed all of the screws.
  • There are ribbons that need to be removed as well. Be sure to carefully pry them off of the board
Hier Übersetzung einfügen
