Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 7 übersetzen
Schritt 7
After you have disconnected all of the ribbon and antennae connections, you can remove the board. Gently pry the board up from the bottom of the case and slide it back out. Make sure to remove all ribbon connectors from the board prior to removing the board. Make sure to remove all ribbon connectors from the board prior to removing the board.
  • After you have disconnected all of the ribbon and antennae connections, you can remove the board. Gently pry the board up from the bottom of the case and slide it back out.
  • Make sure to remove all ribbon connectors from the board prior to removing the board.
Hier Übersetzung einfügen
