Zum Hauptinhalt wechseln
Englisch
Deutsch
4. Schritt
Use tweezers to remove the ribbon. Grab as close as you can to where it plugs in to avoid ripping it. Go from side to side with the tweezers, pulling only a little bit at a time. Be very careful when working with the ribbon. The S9700 may not work if any of it is damaged.
  • Use tweezers to remove the ribbon. Grab as close as you can to where it plugs in to avoid ripping it.
  • Go from side to side with the tweezers, pulling only a little bit at a time.
  • Be very careful when working with the ribbon. The S9700 may not work if any of it is damaged.
Hier Übersetzung einfügen
