Englisch
Deutsch
4. Schritt
Locate the two 10 mm hex bolts securing the bottom of the shock to the lower control arm. They are on the underside of the lower control arm. Remove the two bolts by using a box end wrench or socket wrench to turn them counterclockwise. Hold the shock up against the lower control arm to take pressure off the bolts and make removal easier.
  • Locate the two 10 mm hex bolts securing the bottom of the shock to the lower control arm. They are on the underside of the lower control arm.
  • Remove the two bolts by using a box end wrench or socket wrench to turn them counterclockwise.
  • Hold the shock up against the lower control arm to take pressure off the bolts and make removal easier.
  • Lower the shock out of the lower control arm.
Hier Übersetzung einfügen
