Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Step 2
Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up. Carefully pull the central control cover up along its edges. Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
  • Carefully pull the central control cover up along its edges.
  • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
Hier Übersetzung einfügen
