Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Capacitors come in various shapes and sizes, but the large cylindrical capacitors typically are the ones that store enough energy to be potentially dangerous. Aluminum and Tantalum Electrolytic capacitors can pack a lot into a relatively small volume. They’re well suited to high-voltage applications because of their relatively high maximum voltage ratings. Aluminum electrolytic capacitors, the most commonly used for high voltage, usually look like little tin cans, with both leads extending from the bottom.
  • Capacitors come in various shapes and sizes, but the large cylindrical capacitors typically are the ones that store enough energy to be potentially dangerous.
  • Aluminum and Tantalum Electrolytic capacitors can pack a lot into a relatively small volume. They’re well suited to high-voltage applications because of their relatively high maximum voltage ratings.
  • Aluminum electrolytic capacitors, the most commonly used for high voltage, usually look like little tin cans, with both leads extending from the bottom.
Kondensatoren gibt es in verschiedenen Bauformen und Größen. Die großen zylindrischen Kondensatoren können aber genügend Energie speichern, um gefährlich zu sein.
Aluminium- und Tantalkondensatoren können viel Ladung auf relativ geringem Raum speichern. Sie sind gut für Hochspannungsanwendungen geeignet, da sie relativ hohe Spannungen vertragen können.
Aluminium-Elektrolytkondensatoren werden üblicherweise für hohe Spannungen verwendet. Sie sehen aus wie kleine Metalldosen, die beiden Anschlüsse kommen meistens aus dem Boden heraus.
