Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Before you begin with the dismount procedure of your pneumatic spring you should press your shapeshifter lever once to make sure your bike is in XC mode. Reduce tensile stress by twisting the adjuster on your shapeshifter cable as close as you can to the lever. Reduce tensile stress by twisting the adjuster on your shapeshifter cable as close as you can to the lever.
  • Before you begin with the dismount procedure of your pneumatic spring you should press your shapeshifter lever once to make sure your bike is in XC mode.
  • Reduce tensile stress by twisting the adjuster on your shapeshifter cable as close as you can to the lever.
Bevor du mit dem Ausbau der Luftfeder beginnst, solltest du einmal den Shapeshifterhebel am Lenker bedienen und sicher gehen, dass sich dein Fahrrad im XC Modus befindet.
Reduziere nun die Zugspannung indem du den Versteller am Shapeshifterkabel komplett in die Richtung des Shapeshifterhebels drehst.
