Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Orient the front plate of the device so the display board is facing up. With the spudger, gently work your way around the display assembly. NOTE: The display assembly is composed of three parts and is glued to the case. Be careful to not separate it when prying it out.
  • Orient the front plate of the device so the display board is facing up.
  • With the spudger, gently work your way around the display assembly.
  • NOTE: The display assembly is composed of three parts and is glued to the case. Be careful to not separate it when prying it out.
  • Pry the display free of the front plate.
Hier Übersetzung einfügen
