Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Step 3
Lift the keyboard up, then pivot it towards you to lay it facedown on the trackpad and palm rests. Be careful when lifting the keyboard up. The ribbon cable connecting it to the motherboard is very short, and the connector is fragile. The top corners of the keyboard may be stuck to the laptop bezel with double sided tape.  See rectangles in Image 3.  Be careful as you lift the keyboard up and pivot it toward you.
  • Lift the keyboard up, then pivot it towards you to lay it facedown on the trackpad and palm rests.
  • Be careful when lifting the keyboard up. The ribbon cable connecting it to the motherboard is very short, and the connector is fragile.
  • The top corners of the keyboard may be stuck to the laptop bezel with double sided tape. See rectangles in Image 3. Be careful as you lift the keyboard up and pivot it toward you.
Hier Übersetzung einfügen
