Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen. Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
  • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
  • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
  • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
  • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
Verwende ein iSclack oder Saugheber, um das Rückteil von der Displayeinheit zu trennen.
Nimm das Rückteil noch nicht komplett ab. Das Kabel des Fingerabdrucksensors ist noch mit der Displayeinheit verbunden.
[* icon_caution] Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
black] Use an iSclack or a suction handle to separate the display unitphone assembly from the rear panel.
[* icon_note] In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the
panel.
panel.
[* icon_caution] Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
