Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case. Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
  • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
  • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
Hier Übersetzung einfügen
