Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 11 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Remove the two 3.3 mm T5 Torx battery terminal screws. Grab the blue battery removal tab and lift the battery out to remove it. There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
  • Remove the two 3.3 mm T5 Torx battery terminal screws.
  • Grab the blue battery removal tab and lift the battery out to remove it.
  • There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
  • Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
Hier Übersetzung einfügen
