Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
Step 2
Use a plastic opening tool or your fingernail  to lift up the tab on the rear-facing camera ribbon cable ZIF connector. Make sure you're prying on the tab and not the connector itself. Push the rear-facing camera through its hole in the grey antenna and remove it.
  • Use a plastic opening tool or your fingernail to lift up the tab on the rear-facing camera ribbon cable ZIF connector.
  • Make sure you're prying on the tab and not the connector itself.
  • Push the rear-facing camera through its hole in the grey antenna and remove it.
Hier Übersetzung einfügen
