Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Use a plastic opening tool or your fingernail to lift up the tab on the front-facing camera ribbon cable ZIF connector. Make sure you're prying on the tab and not the connector itself. Lift the front-facing camera out of the antenna with the plastic opening tool and remove it.
  • Use a plastic opening tool or your fingernail to lift up the tab on the front-facing camera ribbon cable ZIF connector.
  • Make sure you're prying on the tab and not the connector itself.
  • Lift the front-facing camera out of the antenna with the plastic opening tool and remove it.
Hier Übersetzung einfügen
