Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
2. Schritt
Locate the two connectors at each end of the FPC. Use the flat edge of a spudger tool or your fingernail to gently pry each connector straight upwards out of its socket, then remove the FPC cable from the unit. While a metal spudger tool is shown here, it is best to use a plastic spudger / opening tool when possible,  and only use a metal spudger as a last resort!
  • Locate the two connectors at each end of the FPC.
  • Use the flat edge of a spudger tool or your fingernail to gently pry each connector straight upwards out of its socket, then remove the FPC cable from the unit.
  • While a metal spudger tool is shown here, it is best to use a plastic spudger / opening tool when possible, and only use a metal spudger as a last resort!
  • You should now see the yellow-colored strip on the metal base marking the location of the FPC
Hier Übersetzung einfügen
