Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Lift the keyboard up, then pivot it towards you to lay it facedown on the trackpad and palm rests. Be careful when lifting the keyboard up. The ribbon cable connecting it to the motherboard is very short, and the connector is fragile. The top corners of the keyboard may be stuck to the laptop bezel with double sided tape.  See rectangles in Image 3.  Be careful as you lift the keyboard up and pivot it toward you.
  • Lift the keyboard up, then pivot it towards you to lay it facedown on the trackpad and palm rests.
  • Be careful when lifting the keyboard up. The ribbon cable connecting it to the motherboard is very short, and the connector is fragile.
  • The top corners of the keyboard may be stuck to the laptop bezel with double sided tape. See rectangles in Image 3. Be careful as you lift the keyboard up and pivot it toward you.
Hier Übersetzung einfügen
