Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Use the tip of a spudger to lift the right fan connector straight up from its socket on the logic board. Be sure to only pry up on the connector itself not on the socket or you may damage the machine. It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  • Use the tip of a spudger to lift the right fan connector straight up from its socket on the logic board.
  • Be sure to only pry up on the connector itself not on the socket or you may damage the machine.
  • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  • Remove the right fan from the case.
Hier Übersetzung einfügen
