Englisch
Deutsch
2. Schritt
With the end of your fingernail press in on the locking quick release tabs on the bottom left and right of the radio.  Once pressed in the tabs will pop out slightly. Gently grasp these tabs and pull them out on both sides of the radio. Insert your fingers into the holes on both tabs, and gently slide the radio out.  You will NOT need to disconnect the power, and antenna connections.
  • With the end of your fingernail press in on the locking quick release tabs on the bottom left and right of the radio. Once pressed in the tabs will pop out slightly.
  • Gently grasp these tabs and pull them out on both sides of the radio.
  • Insert your fingers into the holes on both tabs, and gently slide the radio out. You will NOT need to disconnect the power, and antenna connections.
Hier Übersetzung einfügen
