Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 6
Locate the yellow brackets at the bottom of the device. Using a phillips head screwdriver, remove the single 4mm screw on each bracket, located on either side of the auxiliary port. Lift the brackets from the device and set them aside.
  • Locate the yellow brackets at the bottom of the device.
  • Using a phillips head screwdriver, remove the single 4mm screw on each bracket, located on either side of the auxiliary port.
  • Lift the brackets from the device and set them aside.
  • You may need to use a nylon spudger, or any flat tool, to lift the brackets out of their place.
Hier Übersetzung einfügen
