Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
Position the camera so the bottom is facing up and the display away from the surface. Gently pry the screen portion from the camera portion with your fingers or a plastic prybar. Do not fully separate the two components! the screen is attached by two ribbon cables.
  • Position the camera so the bottom is facing up and the display away from the surface.
  • Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
  • Do not fully separate the two components! the screen is attached by two ribbon cables.
  • Lay the display flat to expose the circuit board and the display control ribbon cables.
Hier Übersetzung einfügen
