Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Upgrading from the 4:3 Small screen display to Widescreen display is quite simple Remove the dash trim pieces on either side of the display.  Using a Phillips screw driver remove the small trim panel screws on either side and gently lift the brass faceplate release mechanism shown in the above photo. See Attached Document BMW TIS - 65 52 510 Removing and installing on-board monitor.pdf for details
  • Upgrading from the 4:3 Small screen display to Widescreen display is quite simple
  • Remove the dash trim pieces on either side of the display. Using a Phillips screw driver remove the small trim panel screws on either side and gently lift the brass faceplate release mechanism shown in the above photo.
  • See Attached Document BMW TIS - 65 52 510 Removing and installing on-board monitor.pdf for details
Hier Übersetzung einfügen
