Zum Hauptinhalt wechseln
Englisch
Deutsch
2. Schritt
This step is not required if you are moving the drive to a Dell computer with the same mounting bracket or for Depot service and want to retain the hard drive. To remove the drive clip, remove the Phillips #0 screw holding the hard drive to the clip. Once the screw is removed, remove the drive starting from the side with the screw.
Remove the drive clip
  • This step is not required if you are moving the drive to a Dell computer with the same mounting bracket or for Depot service and want to retain the hard drive.
  • To remove the drive clip, remove the Phillips #0 screw holding the hard drive to the clip.
  • Once the screw is removed, remove the drive starting from the side with the screw.
  • Remove the drive from the right side by removing the drive from the alignment pin.
Hier Übersetzung einfügen
