Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
3. Schritt
Windows 7 systems have a COA under the battery. Windows 8.x systems have a tamper evident label on the service panel with the product key in the BIOS. Extended runtime batteries are about 1/3 larger then standard batteries. These will stick out of the system. Remove the battery from the computer. Pull the battery up from the back of the battery, and set the battery aside.
Remove the old battery
  • Windows 7 systems have a COA under the battery. Windows 8.x systems have a tamper evident label on the service panel with the product key in the BIOS.
  • Extended runtime batteries are about 1/3 larger then standard batteries. These will stick out of the system.
  • Remove the battery from the computer. Pull the battery up from the back of the battery, and set the battery aside.
Hier Übersetzung einfügen
