Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 5
The large cylindrical object on the right side of the board is the flash capacitor. WARNING: The flash capacitor may carry high voltage, that may persist for hours or even days after the camera has been switched off and/or the battery has been removed.
  • The large cylindrical object on the right side of the board is the flash capacitor.
  • WARNING: The flash capacitor may carry high voltage, that may persist for hours or even days after the camera has been switched off and/or the battery has been removed.
  • Touching the circuit board while the capacitor still holds its charge may result in a painful electric shock that you will long remember.
  • To make the board safe to work on, short out the two marked terminals with a capacitor discharge tool or the blade of a screwdriver or similar implement (with an insulated handle!) You might have to use moderate pressure to punch through the white goop that covers one of the terminals.
  • There might be little sparks and/or an audible pop. Be careful not to short other solder connections nearby.
  • Use a multimeter to check that dangerous voltage is no longer present before you proceed.
  • Unsolder all of the wires on the top of the logic board.
Hier Übersetzung einfügen
