Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 5
To remove the keyboard, push up from the bottom first. Once the lower tabs are released, use a plastic pry tool to lift the keyboard up. To remove the keyboard, push up from the bottom first. Once the lower tabs are released, use a plastic pry tool to lift the keyboard up. To remove the keyboard, push up from the bottom first. Once the lower tabs are released, use a plastic pry tool to lift the keyboard up.
Remove the keyboard
  • To remove the keyboard, push up from the bottom first. Once the lower tabs are released, use a plastic pry tool to lift the keyboard up.
Schiebe die Tastatur zuerst ein wenig nach oben. Wenn sich die Unterkante gelöst hat, kannst du die Tastatur mit einen Hebelwerkzeug aus Kunststoff hochheben.
[title] Remove the keyboard
[* black] To remove the keyboard, push up from the bottom first. Once the bottom is released and the metallower tabs are all released, use a plastic pry tool to lift the keyboard up.
