Englisch
Deutsch
3. Schritt
Using your fingers or a spudger, lift the antenna out of its socket, rotating it toward the bottom of the device. Make sure that the orange ribbon cable passes completely through its hole in the aluminum frame.
  • Using your fingers or a spudger, lift the antenna out of its socket, rotating it toward the bottom of the device.
  • Make sure that the orange ribbon cable passes completely through its hole in the aluminum frame.
Hebe die Antenne aus ihrem Sockel. Drehe sie dabei nach unten.
Achte darauf, dass das orangene Flachbandkabel komplett durch das Loch im Aluminiumrahmen durch geht.
