Zum Hauptinhalt wechseln
Englisch
Deutsch
2. Schritt
The rear glass panel is secured in place by a large amount of adhesive. In order to separate the adhesive, the rear panel needs to be heated, pulled up by a suction cup, and split with opening picks. The removal process was tedious, challenging, and new adhesive will be needed to replace the panel.
  • The rear glass panel is secured in place by a large amount of adhesive.
  • In order to separate the adhesive, the rear panel needs to be heated, pulled up by a suction cup, and split with opening picks.
  • The removal process was tedious, challenging, and new adhesive will be needed to replace the panel.
  • At this point, nothing can be removed other than 8 screws that secure the two parts of the midframe.
  • Although the battery is visible, it cannot be disconnected as the midframe sits above its connector. This makes repairs risky, as power is still supplied to the motherboard.
Hier Übersetzung einfügen
