Englisch
Deutsch
Step 2
Remove the screw which is holding the gearshift in its place with an allen key. Put the gearshifts to the side. Loosen the clamp screw from the Reverb-remote until you can move it.
  • Remove the screw which is holding the gearshift in its place with an allen key.
  • Put the gearshifts to the side.
  • Loosen the clamp screw from the Reverb-remote until you can move it.
Entferne die Schraube welche den Schalthebel (Trigger), an der Klemme des Bremshebels befestigt.
Entferne den Schalthebel.
Löse nun die Schraube der Reverb-remote soweit, das du sie am Lenker bewegen kannst.
