Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 52 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
4. Schritt
Carefully place a suction cup halfway up the heated side. Be sure the cup is completely flat on the screen to get a tight seal. While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
  • Carefully place a suction cup halfway up the heated side.
  • Be sure the cup is completely flat on the screen to get a tight seal.
  • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
  • If your iPad's screen is badly cracked, covering it with a smooth layer of clear packing tape may help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
Befestige einen Saugnapf auf der linken Seite in der Mitte des iPads.
Drücke den Saugnapf flach auf den Touch Screen.
Halte das iPad mit der einen Hand fest und hebe mit der anderen vorsichtig den Touch Screen vom Gehäuse.
[* black] Carefully place a suction cup halfway up the heated side.
[* black] Be sure the cup is completely flat on the screen to get a tight seal.
[* black] While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
[* icon_note] If your iPad's screen is badly cracked, covering it with a smooth layer of clear packing tape may help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and [https://d3nevzfk7ii3be.cloudfront.net/igi/NgVMfmOgJwEalMFF.huge|fold it into a handle|new_window=true].
