Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
There are two adhesive strips in the center of the phone connecting the rear case to the battery, you'll need to remove them to open the phone. When the edges of the cover are free from adhesive, tilt it to allow access to the battery tabs.
  • There are two adhesive strips in the center of the phone connecting the rear case to the battery, you'll need to remove them to open the phone.
  • When the edges of the cover are free from adhesive, tilt it to allow access to the battery tabs.
  • Use tweezers to pull the two black adhesive strips out of the phone but don't pull just yet.
Nachdem der Kleber gelöst ist, hebe die die Rückabdeckung mit dem Saugnapf an.
Nutze eine Pinzette, um die zwei schwarzen Streifen, die an dem Kleber befestigt sind, aus dem Telefon zu ziehen.
[* black] After theicon_note] There are two adhesive aroundstrips in the egdes is loosened, pull upcenter of the phone connecting the rear case to the battery, you'll need to remove them to open the phone.
[* black] When the edges of
the back cover with your suction handleare free from adhesive, tilt it to allow access to the battery tabs.
[* black] Use a tweezertweezers to pull outthe two black straps that are attached to two pieces of adhesive right onstrips out of the batteryphone but don't pull just yet.
