Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Gently pull out both of the adhesive tabs out of the phone, parallel to the rear cover. If the adhesive tabs break, try to use a thin flat plastic tool such as a plastic card to remove the last of the adhesive. If the adhesive is stubborn, heat it with an iOpener or hair dryer and pry again.
  • Gently pull out both of the adhesive tabs out of the phone, parallel to the rear cover.
  • If the adhesive tabs break, try to use a thin flat plastic tool such as a plastic card to remove the last of the adhesive. If the adhesive is stubborn, heat it with an iOpener or hair dryer and pry again.
Ziehe vorsichtig die beiden schwarzen Streifen mitsamt dem Kleber heraus.
Ziehe die Streifen immer seitwärts. Andernfalls können die Klebestreifen leicht reißen. Falls das passiert, nutze eine Plastikkarte, um die Rückabdeckung vorsichtig abzulösen. Erhitze den Kleber erneut, falls notwendig.
[* black] Gently pull out both of the black straps with the adhesive tabs.
[* icon_caution] Never pull
adhesive tabs out of the straps upwards but always sideways. It can easily happen that you rupturephone, parallel to the rear cover.
[* icon_note] If
the adhesive tabs right in between. In this casebreak, try to use a thin flat plastic tool such as a plastic card to pry offremove the back cover carefully, uselast of the adhesive. If the adhesive is stubborn, heat if necessary !it with an iOpener or hair dryer and pry again.
[* icon_note] If
