Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Carefully remove the small suction cup from the corner without moving the screen. Place the small suction cup in the center of the screen and lift to remove screen.
  • Carefully remove the small suction cup from the corner without moving the screen.
  • Place the small suction cup in the center of the screen and lift to remove screen.
  • Make sure to separate all glue under the middle parts of the screen as well as the edges - use a thin stiff card to slice through it. Avoid the ribbon cable. Do not attempt to lift the screen until all glue is separated.
  • The screen is still connected to the rest of the device by a cable, so don't pull the screen up too quickly.
Entferne den Saugheber vorsichtig aus der Ecke, ohne den Bildschirm zu bewegen.
Setze den kleinen Saugheber in der Mitte der Scheibe an, hebe hoch und löse die Scheibe.
Der Bildschirm ist immer noch mit dem Rest des Gerätes durch ein Kabel verbunden, ziehe also nicht zu schnell hoch.
[* black] Carefully remove the small suction cup from the corner without moving the screen.
[* black] Place the small suction cup in the center of the screen and lift to remove screen.
[* icon_caution] Make sure to separate all glue under the middle parts of the screen as well as the edges - use a thin stiff card to slice through it. Avoid the ribbon cable. Do not attempt to lift the screen until all glue is separated.
[* icon_caution] The screen is still connected to the rest of the device by a cable, so don't pull the screen up too quickly.
