Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 14 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 8 übersetzen
8. Schritt
To reinstall the back cover:
  • To reinstall the back cover:
  • First use tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
  • Then, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
  • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
  • Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as Tesa 61395. Be aware that this leaves gaps that are vulnerable to liquid intrusion.
  • If you are installing using pre-cut adhesives, peel the clear backing first. Press the adhesive sheet to the back cover, aligning any cutouts. Finally, peel the colored liner when you are ready to seal the phone.
  • After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
Bevor du die Rückscheibe wieder zusammen baust, musst du erst alle alten Klebstoffreste entfernen.
Wenn alle Reste entfernt sind, reinige die Kanten des Smartphones mit mindestens 90%igen Isopropylalkohol, und bringe dann den neuen Klebstoff auf.
[* icon_reminder] Before replacing your rear glass you will need to removeTo reinstall the oldback cover:
[* black] First use tweezers to peel away any remaining
adhesive from both the phone bodyback cover and the phone's chassis.
[* black] After removing the old adhesiveThen, clean the edges of the phone bodyadhesion areas with high concentration isopropyl alcohol (at least 90%), then apply90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
[* black] Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
[* icon_note] Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as [product|IF317-072|Tesa 61395|new_window=true]. Be aware that this leaves gaps that are vulnerable to liquid intrusion.
[* black] If you are installing using pre-cut adhesives, peel the '''clear backing '''first. Press the adhesive sheet to the back cover, aligning any cutouts. Finally, peel the''' colored liner '''when you are ready to seal the phone.
[* black] After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
[* icon_note] If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
