Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
3. Schritt
Use a plastic opening tool to carefully pry off the back cover. Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other. Be careful to not drop the volume changing piece, for it can easily slip out.
  • Use a plastic opening tool to carefully pry off the back cover.
  • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
  • Be careful to not drop the volume changing piece, for it can easily slip out.
Hier Übersetzung einfügen
