Englisch
Deutsch
Schritt 8 übersetzen
8. Schritt
Starting at the top, use a plastic opening tool to pry open the protective screen on the front of the phone. One of the strips you pulled out of a gate from a previous step is attached to the screen at the bottom. Be careful not to damage it when you are taking off the screen. The protective screen is glued underneath the edges, so it will be a little more difficult to get off.
  • Starting at the top, use a plastic opening tool to pry open the protective screen on the front of the phone.
  • One of the strips you pulled out of a gate from a previous step is attached to the screen at the bottom. Be careful not to damage it when you are taking off the screen.
  • The protective screen is glued underneath the edges, so it will be a little more difficult to get off.
  • Keep your hand underneath the OLED screen at all times because it easily falls out once the protective screen detaches.
Hier Übersetzung einfügen
