Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 14 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
  • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
  • Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
  • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
  • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
Lege den erwärmten iOpener etwa 2 min auf eine lange Kante des S8.
Möglicherweise musst du das mehrfach wiederholen, um das Handy warm genug zu bekommen. Schaue dir die iOpener Anleitung genau an, um nicht zu überhitzen!
Während du darauf wartest, dass der Kleber aufweicht, lies den nächsten Schritt durch, um eine Idee davon zu bekommen, wo du das Werkzeug zum Hebeln ansetzen musst.
[* icon_note] Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
black] Apply a heated iOpener[guide|25705|Heat an iOpener|new_window=true] and apply it to a long edge of the S8 for about 2 minutes.
[* icon_note] You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
[* icon_caution] A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
[* icon_note] As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
