Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
Look closely at the connection between the ribbon cable and the motherboard.  Locate the two grey tabs on either side of the connecting bracket.
  • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
  • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
  • After disconnecting the data ribbon, you can now separate the back case from the front case.
Hier Übersetzung einfügen
