Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone. Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
  • Press the pointed edge of the spudger into the side of the two rubber plugs in order to lift and remove them from the top of the phone.
  • Then, using the Phillips #00 screwdriver, remove the two indicated Phillip screws (6.5 mm).
Hier Übersetzung einfügen
