Zum Hauptinhalt wechseln
Englisch
Deutsch
24. Schritt
Locate and remove the two screws fixing the left metal guard in place using the 3.0 mm Flathead Screwdriver. Remove the metal guard. Perform this step only if you have not already done so in removing the Power Supply. Locate and remove the two screws fixing the bottom right metal guard in place using the 3.0 mm Flathead Screwdriver. Remove metal guard.
  • Locate and remove the two screws fixing the left metal guard in place using the 3.0 mm Flathead Screwdriver. Remove the metal guard.
  • Perform this step only if you have not already done so in removing the Power Supply.
  • Locate and remove the two screws fixing the bottom right metal guard in place using the 3.0 mm Flathead Screwdriver. Remove metal guard.
  • Grasp the CPU Board by the metal tab on the far right.
  • Lift upwards on the metal tab, pulling the CPU Board free of the Motherboard and life upwards to remove it.
Hier Übersetzung einfügen
