Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 21 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4 übersetzen
Schritt 4
With the display panel still lifted, disconnect the four inverter cables. During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush on the edges of the rear case.
  • With the display panel still lifted, disconnect the four inverter cables.
  • During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush on the edges of the rear case.
  • (combined into one plug in on the 24")
  • Be sure to keep track of the cables, as they do not have proprietary sockets. Mismatched cables can cause screen issues.
Während das Display immer noch angehoben ist, kannst du die vier Inverterkabel lösen.
Beim Zusammenbau musst du diese vier Inverterkabel so in Leerräume zwischen den Bauteilen an der Rückwand einsetzen, dass das Display bündig zu den Kanten des Rückgehäuses sitzen kann.
(beim 24" Modell sind sie in einem einzigen Stecker verbunden)
[* black] With the display panel still lifted, disconnect the four inverter cables.
[* icon_reminder] During reinstallation, place the four inverter cable connectors in voids between components attached to the rear panel so the display panel will sit flush on the edges of the rear case.
[* black] (combined into one plug in on the 24")
[* icon_caution] Be sure to keep track of the cables, as they do not have proprietary sockets. Mismatched cables can cause screen issues.
