Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
if you will be using the drive for Windows, format it as NTFS. If you need a multi-OS drive, exFAT or FAT32 is recommended. However, keep in mind FAT32 has a 4GB limit on files.
Format your drive
  • if you will be using the drive for Windows, format it as NTFS. If you need a multi-OS drive, exFAT or FAT32 is recommended. However, keep in mind FAT32 has a 4GB limit on files.
  • Use default allocation size.
  • If you want to rename your drive put the new name here.
  • Start the format. When It's done, you can close all the windows, and you are done.
Hier Übersetzung einfügen
