Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Englisch
Deutsch
Schritt 21
As you lower the display into place, apply gentle pressure against the display's bottom edge so that the top edge stays flush with the top edge of the iPhone. This also prevents the two small gaskets near the home button from scraping against the iPhone's lower edge. Press on the sides of the display near the top of the iPhone, and work your way down to click the display into place.
  • As you lower the display into place, apply gentle pressure against the display's bottom edge so that the top edge stays flush with the top edge of the iPhone.
  • This also prevents the two small gaskets near the home button from scraping against the iPhone's lower edge.
  • Press on the sides of the display near the top of the iPhone, and work your way down to click the display into place.
Wenn du das Display absetzt, dann drücke noch etwas an die Unterseite des Displays so das die Clips oben nicht herausrutschen.
Das verhindert auch, dass die beiden Dichtringe an der Unterseite des Displays verschoben werden.
Drücke das Display von oben nach unten den Seiten entlang auf das Gehäuse so dass es einrastet.
