Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 22
In order for the adhesive to bond correctly, you'll need to apply even pressure around the perimeter of your iPhone. The camera bump complicates matters, but you can compensate by laying your iPhone face-down and placing coins around the perimeter. You can use coins of any denomination, so long as they are as thick or slightly thicker than the camera bump. If your iPhone has a high-gloss finish, such as Jet Black, add a strip of tape around the perimeter to protect the finish before placing any coins.
  • In order for the adhesive to bond correctly, you'll need to apply even pressure around the perimeter of your iPhone. The camera bump complicates matters, but you can compensate by laying your iPhone face-down and placing coins around the perimeter.
  • You can use coins of any denomination, so long as they are as thick or slightly thicker than the camera bump.
  • If your iPhone has a high-gloss finish, such as Jet Black, add a strip of tape around the perimeter to protect the finish before placing any coins.
  • Place a coin at each corner of your iPhone, and place two coins on either side of the camera bump.
  • Place additional coins around the entire perimeter of your iPhone.
  • Using a hair dryer or heat gun, evenly heat the side edges all the way around the iPhone until they are slightly too hot to touch. The heat will help the adhesive form a more complete bond. Don't overheat the iPhone, or you may cause the battery to ignite or damage other heat-sensitive components, like the display.
Damit der Klebestreifen ordentlich anhaftet, muss er gleichmäßig an allen Seiten rund um das iPhone angedrückt werden. Da die Kamera bei allen Modellen hervorsteht, sollte das iPhone mit dem Display nach unten auf den Tisch gelegt und Münzen am Rand entlang platziert werden.
Wenn dein iPhone eine Hochglanzoberfläche hat, wie z.B das Modell Jet Black, dann kannst du vorher einen Klebestreifen ringsherum kleben, um die Oberfläche zu schützen, bevor du die Münzen darunter legst.
Lege auf jede Ecke eine Münze und zwei auf jede Seite der Kamera.
Lege dann weitere Münzen um den ganzen Rand des iPhones.
Erwärme die Seitenkanten rings um das iPhone gleichmäßig mit einem Heißluftgebläse oder einem Haartrockner bis sie so heiß sind, dass du sie kaum anfassen kannst. Dadurch verklebt die Verbindung besser. Überhitze aber auch das iPhone nicht, der Akku könnte sich entzünden oder andere empfindliche Bauteile wie das Display könnten beschädigt werden.
