Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
4. Schritt
Disconnect the hard drive data cable connector from the logic board by pulling it straight up from its socket.
  • Disconnect the hard drive data cable connector from the logic board by pulling it straight up from its socket.
  • The SATA connector on most iMacs tends to stick in its socket on the logic board. If you are having trouble disconnecting the SATA cable, insert a metal spudger or any other thin tool into the gap between the SATA connector and its socket and twist the spudger's shaft to safely separate the two pieces.
Hier Übersetzung einfügen
