Zum Hauptinhalt wechseln
Englisch
Deutsch
15. Schritt
Using a spudger or pick, carefully pry your way around the seam, undoing the clips that attach the shell together. PRO TIP: If you are replacing the shell because your old shell is trashed, don't worry about cracking or damaging the broken shell.  Just go for it.
Separate Body Shell
  • Using a spudger or pick, carefully pry your way around the seam, undoing the clips that attach the shell together.
  • PRO TIP: If you are replacing the shell because your old shell is trashed, don't worry about cracking or damaging the broken shell. Just go for it.
  • Do not try to pull the shell completely apart just yet, there are some cables that must be unplugged first.
Hier Übersetzung einfügen
