Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 22 übersetzen
22. Schritt
Carefully pry off the screw covers on the legs that are attached to the lower shell. Using a T6 screwdriver, remove the two screws.  Repeat on all four corners. Take note on where you are removing the cables from, and install them in the new lower shell in the same way you found them.
Legs & Antenna Cables
  • Carefully pry off the screw covers on the legs that are attached to the lower shell.
  • Using a T6 screwdriver, remove the two screws. Repeat on all four corners.
  • Take note on where you are removing the cables from, and install them in the new lower shell in the same way you found them.
Hier Übersetzung einfügen
