Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 15 übersetzen
15. Schritt
When reassembling your iMac, be very careful to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws. Use a USB flash drive and/or ethernet cable to keep the logic board seated correctly while you tighten the screws.
  • When reassembling your iMac, be very careful to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws.
  • Use a USB flash drive and/or ethernet cable to keep the logic board seated correctly while you tighten the screws.
Hier Übersetzung einfügen
[* icon_reminder] When reassembling your iMac, be very careful to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws.
[* black] Use a USB flash drive and/or ethernet cable to keep the logic board seated correctly while you tighten the screws.
