Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
6. Schritt
Gently pry off the home button cover by inserting the hook of a halberd spudger  or the flat edge of a regular spudger between the cover and the LCD, and gently prying towards the bottom edge of the iPad. Gently pry off the home button cover by inserting the hook of a halberd spudger  or the flat edge of a regular spudger between the cover and the LCD, and gently prying towards the bottom edge of the iPad. Gently pry off the home button cover by inserting the hook of a halberd spudger  or the flat edge of a regular spudger between the cover and the LCD, and gently prying towards the bottom edge of the iPad.
  • Gently pry off the home button cover by inserting the hook of a halberd spudger or the flat edge of a regular spudger between the cover and the LCD, and gently prying towards the bottom edge of the iPad.
Setze den Haken eines Hellebardenspudgers oder das flache Ende eines normalen Spudgers zwischen Abdeckung und LCD. Heble dann vorsichtig die Abdeckung des Home Buttons in Richtung Unterkante des iPads ab.
