Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 17 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
6. Schritt
Slide the pick along the edge of the display, towards the headphone jack. If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat. Be careful not to let the opening pick slide between the fused LCD and front panel, as doing so can permanently damage the display.
  • Slide the pick along the edge of the display, towards the headphone jack.
  • If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
  • Be careful not to let the opening pick slide between the fused LCD and front panel, as doing so can permanently damage the display.
  • A good rule of thumb is to never insert the opening pick more than a quarter inch (6 mm) into the iPad.
Fahre mit dem Plektrum an der Kante des Displays in Richtung der Ohrhörerbuchse entlang.
Wenn doch noch ein stärkerer Widerstand dabei zu spüren ist, wiederhole die Erwärmprozedur mit dem iOpener.
Achte sehr darauf mit dem Plektrum nicht in die Verbindung zwischen Frontglas und LCD Schirm zu geraten, das könnte das Display irreparabel schädigen.
Als gute Faustregel gilt das Plektrum nie mehr als ca 7 mm einzuschieben.
[* black] Slide the pick along the edge of the display, towards the headphone jack.
[* black] If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
[* icon_caution] Be careful not to let the opening pick slide between the fused LCD and front panel, as doing so can permanently damage the display.
[* icon_note] A good rule of thumb is to never insert the opening pick more than a quarter inch (6 mm) into the iPad.
