Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 17
With the upper-burr-holder all the way down, reverse direction on the grind-adjuster and rotate through 50% to 75% of a rotation. Stop when the stop-screw is right above the plastic stop shown in the first picture.
More grind adjuster alignment
  • With the upper-burr-holder all the way down, reverse direction on the grind-adjuster and rotate through 50% to 75% of a rotation.
  • Stop when the stop-screw is right above the plastic stop shown in the first picture.
  • The lip should be about the height shown in the first and second pic. That's critical for your grind to match up with the labeling on the chrome-adjustment wheel after this is all done.
  • Compare the lip height with the photo you took in Step 11. Make sure the gap looks the same.
  • Screw the stop-screw back in.
  • Optional Modification: If you desire a finer grind capability than normal, mark the original stop-screw hole, and then move the stop-screw a few holes clockwise. Then rotate the upper-burr-holder counter-clockwise till the screw hits the stop again. Make extra sure the burrs do not touch if you do this!
Hier Übersetzung einfügen
